Classic All 'historic' bikes.
here comes a stupid question...
Old 04-08-2006, 09:29 PM
Springer Kid's Avatar
Springer Kid
Springer Kid is offline
3rd Gear
Default here comes a stupid question...
What is the easiest way to tell a shovelhead from an ironhead? is an ironhead a shovelhead or vise versa? ok two stupid questions but hey I'm trying to learn here!!!
Old 04-08-2006, 10:56 PM
QT Hush's Avatar
QT Hush
QT Hush is offline
Default RE: here comes a stupid question...
A Shovelhead is a big twin that was manufactured from 1966 until the evolution motor came out in 1984. I think it was 1984. An ironhead is a Sportster motor, although I'm not sure if it's still called that.
Old 04-08-2006, 11:59 PM
pococj's Avatar
pococj
pococj is offline
Received 1,297 Likes on 484 Posts
ORIGINAL: Springer Kid
An Ironhead ain't a Shovelhead, and a Shovelhead ain't an Ironhead.
Shovelhead = Big Twin, engine & transmission separate, coupled on the left side by the primary. Pushrods are at different angles, as they share one camshaft. Generator Shovel - 1966 - 1969. Alternator Shovel, aka Cone Shovel - 1970 - 1984, although some early 1985 models may have had Shovel motors.
Ironhead = Sportster, engine & transmission share a common case, aka unit construction. Pushrods are parallel to each other as each has its own cam. 1957 - 1985.
The following 2 users liked this post by pococj:
2003 (09-28-2021), AJSHOVEL (07-30-2021)
Old 04-09-2006, 11:18 PM
Springer Kid
3rd Gear
Thanks QT Hush and pococj. I'm new to the harley scene and glad I found this place. I hope to learn a lot here...and share as much as I can as well. Thanks again, Al a.k.a. Springer Kid
Old 03-29-2007, 10:45 PM
Hoze's Avatar
Hoze
Hoze is offline
6th Gear
pococj is correct of course , use this simple rule from far away, if the chain/belt is on the left (viewed from the rear) it`s a big twin. If it`s on the right it`s a Sportster. Same rule applies for Flatheads, left is 74 or 80 cid, right is a 45. 45`s morphed into K models (unit construction flatties of 45 and 55 cid)and K`s turned into Sportsters with the adoption of overhead valves. ALL V`s U`s W`s K`s and XL`s have 4 cams, one for each valve.
Old 03-30-2007, 06:22 AM
ChiefGator's Avatar
ChiefGator
ChiefGator is offline
Hmm didn't know that about the Flats... Thanx Hoze.
Old 03-30-2007, 06:32 AM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,349 Likes on 1,520 Posts
Springer Kid...there are no stupid questions, just foolish people who don't ask (when they should) and end up screwing up or who try to impress others with their lack of knowledge.
Old 03-31-2007, 08:42 PM
strickrodt70's Avatar
strickrodt70
strickrodt70 is offline
I asked a similar question a week or two ago. Look under classics (same place as you posted your question) and click on "engine history question". I got some great info there.
Old 07-04-2021, 03:37 PM
Riceburnerfb1's Avatar
Riceburnerfb1
Riceburnerfb1 is offline
Does a magneg stick to the cylinder head?
Old 07-04-2021, 03:44 PM
JustDave13's Avatar
JustDave13
JustDave13 is offline
Received 15,100 Likes on 6,141 Posts
framda
01-19-2011 08:18 AM
Bridgeendfarm
10-19-2008 03:45 PM
Broken Leg Rider
Ironhead
22
10-05-2008 08:50 AM
bmorebhoy
05-28-2008 07:54 PM
bhollis
Classic
09-19-2007 12:49 PM
Quick Reply: here comes a stupid question...
