just got a 69 Harley sprint. what oils do I use?
chefkanuck (03-27-2018)
The owners manual (pictured above) recommends medium heavy for normal use above 40 degrees.
I have always used medium heavy oil in all of my old bikes, Sprints and Big twins.
The cans use to say medium heavy on top, as time went on they said 40 wt. So use straight 40 weight motorcycle oil.
If you can't find that you could get away with 50 weight unless it gets really cold.
Also as mentioned on another post pull the plastic screen (oil filter) out, wash it and put back in.
If the screen is missing I would recommend getting one.
By the way the 40 weight (or 50) is for everything. The engine and transmission is all the same compartment.
Same oil fill / dipstick on right side of engine, same big drain plug / filter on bottom.
I would fall short of calling them a pile of crap but they can be bullheaded and need to be kept in tune and maintained properly to run right.
If you don't do that or don't know how it can cause a lot of headaches.
iglideUC
06-09-2013 04:52 PM
Devils Cut
The General Motorcycle Forum
07-30-2012 02:10 PM
