Classic HDF Photos CVO's, EVO's, Customs, Classics, Sidecar and Trikes
Need Identify Enginenumber
Old 12-17-2023, 06:27 AM
Speedtwin's Avatar
Speedtwin
Speedtwin is offline
Default Need Identify Enginenumber
Hello ,may somebody can help me to identify the enginenumber from a rare 1925 Harley Davidson IOE 61ci .It is an Export Model with electrical system and rear and sidecar Brake.
the number is 25FHA and 3 numbers.Thanks lot forward for any Information.
Here same looking numberblock from a 1924 JE Engincase
1924 case
1925 FHA Engine -a rare Street Model FHA. the engine cases are like the 1924 JE Cases.
Old 12-17-2023, 07:58 AM
Rogue1's Avatar
Rogue1
Rogue1 is offline
Now there's something you don't see every day.
The following 2 users liked this post by Rogue1:
Speedtwin (12-17-2023), Vec (12-19-2023)
Old 12-17-2023, 11:20 PM
Speeding Big Twin's Avatar
Speeding Big Twin
Speeding Big Twin is offline
1924 case
Jörg, welcome to the forum. I received your PM. For 1925 models doesn’t the F usually indicate magneto? Wouldn’t an electric model have the letter J instead of F?
Street model FHA? Can you elaborate on ‘street model’ please.
I can’t tell much about the engine number from that photo. Can you post a clearer picture. And when you say ‘25FHA and 3 numbers’ do you mean the sequence portion only has three numbers in total, including what appears to be a 5?
I haven’t done a lot of research on 1920s engine differences but the R-H side looks more like early/mid-22 or earlier? Do the cases have belly numbers? If so can you post partial photos of both of them.
Does the frame have a number? It may be stamped on the top tube or on a small plate that is attached to the top tube.
Does the transmission case have an ID number? It may be stamped at the back.
Eric
Speedtwin (12-18-2023)
Old 12-17-2023, 11:45 PM
Speedtwin's Avatar
Speedtwin
Here a close picture.The numbers not like the factory production once.But they did like this.Very hard to get information about that.I am starting getting confused about that research (
Old 12-17-2023, 11:50 PM
Speedtwin's Avatar
Speedtwin
Just known that this 1925 Engine Case is like the JE 1924 one ( same case like this) This one is a export model ,with Elektrik,delieverd to a Munich Dealer ( Logo is on front Fender).Still do not have the framenumber,owner told me also starts with FHA.This is a Street Legal Version owner told me ( they build just a little quantity of that model ).Here some more pictures.
Vec (12-19-2023)
Old 12-17-2023, 11:51 PM
Speedtwin's Avatar
Speedtwin
Vec (12-19-2023)
Old 12-17-2023, 11:57 PM
Speedtwin's Avatar
Speedtwin
Vec (12-19-2023)
Old 12-17-2023, 11:59 PM
Speedtwin's Avatar
Speedtwin
Vec (12-19-2023)
Old 12-18-2023, 12:02 AM
Speedtwin's Avatar
Speedtwin
The fast 1924 JE Super Speed ( see the case is diffeent to all others-like the 1925 case)
Old 12-18-2023, 12:07 AM
Speedtwin's Avatar
Speedtwin
and here the last Photo i have
Vec (12-19-2023)
Quick Reply: Need Identify Enginenumber
