Pingel petcock output slight smaller than S&S carb inlet...problem?
I have a pretty built motor about ready to fire up. About to run the fuel line, but I noticed the inlet to the S&S 'G' is 5/16", while the outlet from the fuel tank shutoff is closer to 1/4". Think I'll have any fuel delivery issues from the smaller tank outlet? I doubt it would be an issue other than on a full throttle blast where I might then have the potential of draining the fuel bowl... but I'd rather that not happen.... at the same time, I just bought the shutoff...don't really want to replace it already unless I need too. hasn't even had fuel through it yet!
Motor specs:
110" (plus .010 over) stroker
S&S 625G ez start cams
Ported CVO heads
S&S G carb and intake
etc
Motor specs:
Ported CVO heads
etc
