Super E o-ring and check ball question.
http://aardvarkcycle.com/sscycle_carbs_large.htmlhttp://aardvarkcycle.com/sscycle_carbs_large.html
So I'm rebuilding my Super E and I've ran across a couple of problems (my last problems, everything else is together)...according to this diagram it shows that it goes: check ball THEN spring in the pump cap assembly, is this correct? I just can't remember from when I took it apart.
Also, my master rebuild kit came with a TINY o-ring (smaller than the ejector nozzle o-ring), and I totally don't remember this one at all...any thoughts on it?
http://www.bikernet.com/pages/story_detail.aspx?id=7153
Here I think they talk about it down by the ejector nozzle picture, but don't mention where it goes. Thanks for any help!
Okie doke...should've just done this in the first place. I called tech support at S&S and they informed me that the tiny o-ring goes on the idle mixture screw (if it has a groove for it, if it doesn't, don't worry about it). As for the check ball and spring, if you're looking at the float bowl and it's upside down, it goes spring then ball (the ball should be facing the outside of the carb). Hope this helps someone!
