CV experts needed
You can get a 46 slow jet at cv-performance.com, I would try that and a 185 in a stock engine. Which needle are you running in there now? From reading the thread, I think your carb was completely stock.The stock needle did have grooves in it for adjustment purposes, at least the one in my parts manual shows grooves. I have an '06 but my carb was modified before I bought the bike and had a different tapered Keihin needle in it. To get the correct main jet there are 2 different things you can do: if you want to check a/f mix at WOT by checking the plugs, you have to do a "plug chop". Google it. Or, you can go to a back road that is fairly straight and no traffic with a friend who will time some 1/4 mile runs at WOT for you. Use a couple telephone poles or other landmarks to use as start and finish points. You have to be going like 60 mph in 5th gear already at the start line so it's a running start.The main jet that gives you the fastest time is the one to use.
We hit N. Ga. this weekend with the 190 and 48 in it. Cold she acted like she wanted the 50 back in; I had to keep the enrichener pulled for a lot longer.
Warmed up, the roll-on from 60 to 80-85 was lackluster, and it has a slight bog if I give it too much too early, indicating richness to me. As we hit the twisties (my regular playground), I could tell she was not doing quite as well as the 175, but this also could be due to humidity, temperatures, pressure and so forth. Also, she seemed to have good power if I let her wind up tighter than I like to, also indicating rich.
I'm gonna see if I can come up with a 180 or 185 this week to try next. Unfortunately, there is a rather tight police presence around here lately...and this east coast just has TOO DANG MANY PEOPLE!
When I get closer I may do some plug chops, but I believe it's not very healthy for an engine to cut like that at full heat and minimal cylinder oiling.
The Harley 185 won't fit; different threads, indicating that yes, it's a dynajet kit, from what I've read tonight. I did find something interesting though, that may help or at least not hurt - I put the 48 back in, then found this power tube for $16 -http://www.harley-performance.com/cv-performance-parts.html
-called the CVP Velocity Emulsion Tube.
At least it will hold the stock Harley jet threads so I can use the one I bought. Can't find a review on it yet.
Battery dead so couldn't test anything tonight. Stoopid Garmin turns itself on at night if I don't unplug it. Guess i got more than one gremlin after all...
oh yeah...what about contouring the slide? Any good in this situation? I'm pretty good with tools and I've got a lot of 'em.
Whose kit? What type of needle does it have? I put a 180 in it tonight to test at a club meet tomorrow night, and bought a 185 also. Tightened up a very slight exhaust leak I found (clamp was a little offside).
Mech told me today that there are a few needles out there that can make a difference, especially for fuel mileage, but all I see in each kit is one. My manual doesn't show grooves in the stocker, so I assume mine's part of a dynajet kit.
I mentioned that I'd already used the '88 needle - they're not known for fuel efficiency, and that's the reason I took it out and went back to the adjustable needle. I found out the hard way I guess.
Crap. I just realized I didn't try to adjust the needle this weekend; I just assumed the jet was rich from the boggy spot - I wonder if the upper crossover is viable to the needle or is it just the lower end crossover to the pilot jet?
Not like it's a quick adjustment either.
Man, you got that one right! I had dropped it all the way down one notch at a time until it ran lean (with the 175 in it) and backed up one notch, where it still is.
Tonight saw a 40 degree ride to a meeting after realigning the rear muffler clamp to eliminate the slight leak. The popping was gone completely! The 180 seems to be doing okay, but I'd like to be able to get it warmer (*tomorrow) to see how she runs. I may stay here for a tankfull or a run (two tankfulls, usually) to check the mileage.
You're a bit large on the low jet.
I would go with a #46 low jet and that should put your idle adjustment at around 2 1/2 turns out , then adjust it from there to reach the highest and steadiest idle , then adjust the idle speed after it's completely warm. The poor MPG is due to the large jetting on the low end.
2 #4 washers under a stock needle will give you as much as you can get with any jet kit.
