Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Enrichener
Old 03-01-2011 | 10:57 AM
frbeall's Avatar
frbeall
Question Enrichener
I have a question. How long do you keep the enrichener open during warmup? I've had a fouling problem and have started using the throttle lock after a few seconds.
Old 03-01-2011 | 11:06 AM
NickD's Avatar
NickD
I'm in SoCal so I don't experience too many very cold weather starts, but I do the same thing. Leaving the choke on too long, as it delivers less air and more fuel, can foul your plugs. Basically I use the choke just to get the motor to fire but only leave it on for about ten seconds or so. After that it's all throttle control.
Old 03-01-2011 | 12:33 PM
Hammerhead Pat's Avatar
Hammerhead Pat
I pop the throttle once or twice and them pull the choke out as I'm hitting the start button,after it starts up the choke is only on for 10-15 seconds at tops.
Old 03-01-2011 | 07:37 PM
shedsruty59's Avatar
shedsruty59
In the cold i may run allday with it 1/2 way, When it is hot stop drop and roll!
Old 03-01-2011 | 07:43 PM
Nabubba's Avatar
Nabubba
All the way out when I fire it up then drop it to half within a couple of seconds and leave it a half till I get to the end of my neighborhood at the main road. If it is warm then I shut if off when I start rolling.
Old 03-02-2011 | 07:40 AM
frbeall's Avatar
frbeall
If I leave mine on that long I'll foul plugs and I don't understand why. For 8 years I've never had this problem. Since using the lock after a few seconds the fouling has stopped. Have already cleaned, jetted and adjusted mixture. I'm confused
Old 03-02-2011 | 06:45 PM
Nabubba's Avatar
Nabubba
Only think I can think of is you are a bit too rich.
Of course I only do that when it is in the low 30's. Other then that it is just a few seconds and I am on the throttle rolling.
Old 03-05-2011 | 07:33 AM
chappy99's Avatar
chappy99
i just use it to get her running,then use the pin wheel to let her warm up,i had the same problem fouled plugs.
Old 03-05-2011 | 07:37 AM
Stiggy's Avatar
Stiggy
This is an example of a bike jetted too lean. Intermedate jet needs to go up a notch.
Gooberguy
07-20-2011 10:37 AM
HarleyNation
04-09-2011 02:26 PM
montana dan
08-27-2007 12:13 PM
spottedfool
08-26-2006 01:00 AM
pig iron
Exhaust System Topics
04-13-2005 01:09 AM
Quick Reply: Enrichener
