05' 1200C Sportster Enricher cable replacement
I'm stuck. I had to replace my enrichment cable due to the **** breaking off. I looked at several places on the net for this instruction.
This is where I'm at.
I did not remove the tank. I removed the a/c, pulled off the carb, removed a vac hose. Left the throttle/idle cables intact. There is a fuel hose that comes from the tank has a clamp that looks like its for one time use. I need to remove this hose in order to screw in the enricher cable cap into the carb. Can I use a small hose clamp to replace the original?
Any tips would be appreciated.
