just tuned using the sticky suggestion a few questions
Ok i just tuned put a #46 pilot jet and got the #4 washers put two under the needle i measured the 2 washers they are actually .059 turned the idle mixture out 2 1/2 turns and man it runs great no more fealing like its stumbling at 75 anymore is the .059 gonna hurt me? Also I have the stage 1 se air filter with stock headpipes and stock mufflers that have been gutted but have some sort of performance baffle in them. The question is i am going to put a set of rush slip ons on will this still work for me? Or do I then need to put a bigger main jet in. thanks
Do you have an 883 or a 1200? I think I have a 48low and 170Main in my 883 with SE aircleaner and slipons. I did get an EZ adjust for my pilot.http://www.harley-performance.com/ez-just.html
ok folks been riding with my setup for about 700 miles runs great getting around 43 mpg the only thing is after its warmed up i have to most of the time hit the throttle twice and hold it open just a very little bit and it fires right up. The spark plugs color looks good. does this sound normal? I am a harley virgin so im learning as i go.
