'02 RK (carbed), won't start: need help with troubleshooting
Received 4,807 Likes
The crank position sensor works off the "hall effect" senses the the teeth on the flywheel and when an empty spot shows up it sends a signal to the ignition module, then to coil and produces the spark. Wish I had seen this post a little sooner could have helped you out. During oil changes an errant oil filter wrench can reek havoc on this sensor.
Rockabill
04-20-2015 06:54 AM
