Setting up Mikuini HSR 42 on 1550
The carb should run pretty good for you out of the box. You might need to play with the main jet a little. I have a similar combo and I am running the stock pilot jet (25) and a 167.5 main jet with a 1 stage leaner needle on the middle clip. Your elevation with play into your final settings also..
ccondon23
Exhaust System Topics
07-28-2007 08:45 PM
