1995 Ultra Classic Electra Glide HDMFLHTCU95
Where can I get an oem carb plastic backing plate. After nearly 30 years the part of the backing plate due to vibration that you bolt into the cylinder head is slipping over the steel sleeve and allowing the carb to move away from the inlet. Just age. But I'm on the lookout for either a new oem one or ideas on the fix. Thankyou from way way down under
