Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
dies with throttle
Old 08-19-2024, 12:14 PM
mrk44's Avatar
mrk44
mrk44 is offline
Default dies with throttle
i rebuilt and cleaned my 2002 dyna carb. gas is coming in with throttle and vacuum piston move up with throttle and then bike dies immediately. to make sure carb was clean, i cleaned it a second time with the same results. any ideas? thanks!!
Old 08-19-2024, 12:27 PM
Bott's Avatar
Bott
Bott is offline
Does the bike idle? Takes 3 circuits to start/idle/WOT. No orifice shuts down or closes off meaning. Tank's gas cap vent is closed? Battery is 12.8v or higher?
Old 08-19-2024, 01:14 PM
t150vej's Avatar
t150vej
t150vej is offline
Received 1,813 Likes on 1,176 Posts
Upside down needle jet is most often the culprit and very easy mistake to make.
The following 3 users liked this post by t150vej:
Chasingdrakes (08-19-2024), djl (08-19-2024), Yankee Dog (08-19-2024)
Old 08-19-2024, 02:53 PM
mrk44's Avatar
mrk44
mrk44 is offline
bike idles just fine. brand new harley caps. brand new harley battery. thanks!
Old 08-19-2024, 02:55 PM
mrk44's Avatar
mrk44
mrk44 is offline
yes, needle jet in the right way. thanks!
Old 08-19-2024, 03:05 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,956 Likes on 4,151 Posts
Take that brand new Harley cap off.
What was it doing before you cleaned carburetor? If it's cutting out instantly, it's probably electrical.
Old 08-19-2024, 03:45 PM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 2,031 Likes on 1,028 Posts
What are Harley Caps? A hat?
Hey Babe...Like my cap?
The following 2 users liked this post by Yankee Dog:
pgreer (08-19-2024), t150vej (08-19-2024)
Old 08-19-2024, 08:12 PM
mrk44's Avatar
mrk44
mrk44 is offline
tried it with caps off, same result. yes, it cuts off instantly. when i throttle the vacuum piston goes up a little. i manually lifted the vacuum piston and gave it throttle and it revved and didn't die. could that mean there is a leak in the vacuum piston? i checked it for hole with a light and didn't see anything. thanks for your help!! if it is electrical, what would i look for?
Old 08-19-2024, 08:17 PM
mrk44's Avatar
mrk44
mrk44 is offline
oh, it ran well before i cleaned the carb. i did rewire for new handlebars and put a new tank on it. cleaned carb cause i figured i might as well since bike was apart. all lights works. thanks!
Old 08-20-2024, 01:18 AM
t150vej's Avatar
t150vej
t150vej is offline
Do you have the vacuum hose to the voes and petcock connected?
Quick Reply: dies with throttle
