Breather bolt stuck
Received 22,102 Likes
pgreer (07-27-2024)
The following 2 users liked this post by TwiZted Biker:
chopper_man (07-28-2024),
NorthWestern (07-27-2024)
This, right here. Grind the face of a good SIX POINT socket as flat as possible, don't use a 12 point, and lean into it! Put as much pressure as you can straight into it to keep the socket straight and flush while turning.
The following 2 users liked this post by NorthWestern:
TwiZted Biker (07-27-2024),
Yankee Dog (07-28-2024)
super + 1 on the 6 pt.
steel insert, hummmmmm, haven't seen it but never say never
there are two issues
1. iron/steel and aluminum are dissimilar metals and they will cause electrolysis which fuses them together
2. the assy was over torqued and now there is a failure in the head material and when you try and back it out, thread locks.
