Intake manifold removal question
WP50 (05-15-2022)
guidowitz (05-15-2022)
guidowitz (05-16-2022)
Sadly it looks like the stock hex bolt that someone stripped the hell out of. Try some liquid wrench or other type of nut buster and let it sit awhile. A little pen torch to get a little heat on them will help too. Just removed mine a few hours ago and I'm pretty its a 1/4" hex...but I just know which one of mine to use and didn't actually look at the size
So correct. The 1/4 allen heads have been badly damaged. I used a shortened allen to gain access after solvent and pen torch to no avail. Unable to gain a respectable purchase on these burgered fasteners
My next bright idea is to cut the manifold off
to better tackle to issue since the manifold is for an S&S carb and I’m using a stock CV 40 mm so I can waste it ☹️
