Super G to Super E swap
Hello all!
New member here with a question....
I have a 1985 FLHTC that has a Super G carb currently. I am swapping to a Super E as it has never run exactly right. I have read that the G is normally used for larger motors than my stock 80".
So, I have a used Super E with a 367 intake manifold. Will that manifold work for this application? I assume I will need flanges, but am unsure as to which part number would be correct.
An information you have would be helpful!
Thanks!
Thanks!
I don't know about your manifold number, I do know that the E and G carbs DO use different manifolds due to demensioal differences between the 2 carbs. Get yourself the manifold for the E carb and have fun. The folks at S&S can help you figure out what you have if you just give them a call.
m
m
