Carburetor tuning screws
One is idle one is mixture , the one with the x in it is probably the idle screw and the other a mixture screw , probably . I know that may not help but I'm 99% sure.I don't know that carb is all.
It's just for me they're in an odd position they're usually somewhere else,usually near the bottom front/side of the carb. , google the type of carb and go from there.
Carbs are a "make one change at a time " thing so you can go back one step if **** gets weird.
ARNAV (04-08-2021)
The following 2 users liked this post by jbarr1:
98hotrodfatboy (04-08-2021),
ARNAV (04-08-2021)
It will adjust the when of the pump to come in more than likely. Most have a linkage or rod that can be adjusted to time the accelerator pump to work with the opening of the throttle , the nozzle also comes in a few different sizes too. If it comes in too early the engine could bog down a little , too late and it's too lean .The fuel stream it produces should hit the needle to atomize in the stream. Fk I'm old I can't even remember the workings of an S@S carb , I used mostly Mikuni's with my Shovels and Evos or the stock CV carb.
ARNAV (04-09-2021)
Engine won’t run if I won’t open the chock, just a little. If the chock is fully closed then rpm become too low and engine stops.
The left mixture screw - is fully closed, if I start opening it even a little, the rpm get too low and the engine stops..
The right acceleration pump screw - I don’t see any difference between having it close or open...
Carburetor diagnosis over the phone/net is all fked up mate , what might sound like a lean bog/hesitation to you could mean a rich flub/stumble to me .
Write down the state of tune of your bike then find that bike and carb combination on this forum and ask those guys their jetting settings. Find settings and buy those jets , set the needle where those guys have theirs. There was a sight called shade tree tuners or something that had settings going way back as well. Call your Indy he'll know or just take it to him and watch and learn.
Remember one change at a time AND the float must be at the right height before you go further .Most floats start letting fuel through when the float is parallel to the world or parallel to the bottom join edge of the bowl where it seats.
Sorry I can't be more help, you'll get it.
I found the site dude
http://www.nightrider.com/biketech/Pro_tuning.htm
It'll be there somewhere. the drop down menu on the right is the ****.
acc pump is used to bridge and smooth the gap between intermediate and main jets when you crack the throttle quick
to The OP you might want to look up the S&S tune procedure. You’re talking adjusting the mixture screw that only affects the idle circuit. You should first make sure you have the right size intermediate jet.
Agoober (04-10-2021)
Make sure the bikes warmed up before messing with it.
