Carb spit back
Carb spit back
I have a carbureted, 2000 Heritage Springer, modified to a 107 ci CNC ported Screaming Eagle head and a Screaming Eagle Mikuni carb. About every other time, when I shut it down, I get some kind of spit, or coughing back thru the high flow cone air filter. It is kind of a exhaling sound. Sometimes it is loud, other times not so loud. Sometimes smoke comes out the filter. What could be causing this?
I have S&S Quickee pushrods. I have checked their adjustments, and they are up to specs, set at four turns. The bike runs great at all speeds. I do have Dynatek re-programmable electronic timing, but I know nothing about it, and I am hesitant to mess with it. The sparkplugs are all full of black soot. Does that indicate it is running rich? One thing I did notice, is that recently, gas has been dripping from the carb's plastic drain hose onto the ground after I shut off the engine (with gas valve in off position). I suspect the carb float and/or needle. I think I will be taking it to an indy shop to have them take a close look at it.
2006ultra
10-26-2005 07:17 PM
