Fuel leaking from carb
I have a 2000 HD Springer with a Mikuni carburetor, but which is stamped on the top with the Screaming Eagle logo. Today, after shutting it off, I smelled gas, looked underneath the bike and saw a puddle of gas. I then saw gas dripping out of the plastic hose that comes out of the carburetor. I know that the purpose of the hose is to expel excess gas, but to have a continual drip does not appear normal. Is this a sign that the float is not seating right and not shutting off the flow?
Received 1,105 Likes
You are probably correct. Or it could be the float is waterlogged ( I don't think this happens anymore) or somehow the needle adjustment is out.
I just had this problem on an older machine , removed the bowl and float and took a picture up inside the float seat, there was a tiny sliver of rubber stuck there. Removed it and back on the road.
Originally Posted by Baird;[url=tel:19660493
19660493[/url]]You are probably correct. Or it could be the float is waterlogged ( I don't think this happens anymore) or somehow the needle adjustment is out.
