Pilot jets?
T1 I have V&H straight shot pipes replace the tensioners with gears and have a Andrews 37 cam with Arlin Ness big air sucker breather. stock needle the dynojet needle didn't hear too many nice things about.
just did a long ride and the mpgs went from 49.8 to 40 mpg?? this cv40 is driving me nuts!! although the hiccups are now at idle and start off verse starting acceleration.. not sure which is worse?
Check or replace the little o-ring that seals the idle mixture screw, if you are confident the carb has a good seal at the intake it could be sucking air there. I usually put a little silicone grease on mine to prevent it from drying out or wearing out from me always messing with it trying to find the perfect setting haha
Garage Queen Rescue (12-28-2020)
I only read from post #12 down so.... REW, you've not mentioned what cam, pipes you're running. For now I will say 45/175 is plenty for a stock cam. 48/190 is about max for most bolt-in performance cams unless it's had head work. Does it have a stock type needle or are you working with Dynojet needle and jets?
Symptoms in post #12 sound like possible slide diaphragm leaking and post #17 coughing off idle could be deficient accelerator pump squirt. Both guesses are assuming you have no intake leaks,VOES is working and engine warmed up.
My apologies for "stepping in it" earlier and I've no idea whether the manifold sensor is an on/off or variable resistor type but I'd try to verify it's working correctly before dropping $$ on a new carburetor.
LOL. Good thing I like eggs because my face is covered in them right now... Should have asked whether it was TC or Evo before I opened my mouth
I'm admittedly and willfully ignorant about TCs but know those carbs fairly well. I don't think you're too far off on the jetting where you are now or maybe even where you were. I'm just guessing but especially with the drastic drop in fuel mileage I'd be considering timing (advance) as a possible issue. Evo uses a VOES, yours has a manifold pressure sensor that sorta does the same thing. If it's leaking, sticking or otherwise not dong right, that'll cause all kinds of weird readings by the ECM pertaining to ignition timing.
This was my MAP sensor:
Cheers!
t150vej (12-29-2020)
Crap.. Should have said it's an 01 TC, bought more gaskets today going to try the intake gaskets and if that doesn't work it's a mikuni time...
I have to ask timing? I know that I can't hook up my timing light like I do my car? Wouldn't that have more hesitation in acceleration if it were off?
Do check that MAP sensor on the top of the intake for cracks, before pulling the trigger on a new carb.
Cheers!
Honestly I never paid attention to the object on top of the intake.. I know that all of my cars have them.. Didn't think the bike had one.. I will definitely check out the MAF sensor.. Makes since thinking about it now..
I had a dynatek ignition in it but wasn't a big fan of it, seemed like I was eating plugs with it and couldn't get it dialed in properly, so I went back to the stock one.
With your engine, intake and exhaust mods, you need a programmable ignition module. The stock module with the factory table(s) won't be right for your build. I would recommend the DTT TC88A, and a good dyno tune. I would bet that will solve your issues.
Cheers!
Clammy (01-04-2021)
Alright alright alright...... Replaced seals, and found an open vacuum tube on the backside of the carb... Plugged it and only got one hicup. Waiting for a nicer day to put some miles in the seat to check out the mileage and see if there are any more hicups... Hope not.
Or it will be kuni time
