27412-99c Carburetor
I have a 2002 Electra glide classic, I don’t have the time or patience to do a rebuild on my carburetor. So I’ve been looking to just replace it with another and finding mostly 27421-99c instead of 27412-99c.
Can anyone tell me what the difference is?
Also, what other replacement carbs would work as good and fit straight in.
Thanks.
Thanks.
I will break it down properly when I have more time. It doesn’t idle right, back fires some, can’t get it dialed in right. I have a family member who just bought a bike and I need to get riding. I just thought of putting in a new one now and rebuild mine later. But the only new ones I could find have a slightly different serial number.
Received 1,104 Likes
I agree rebuilding the carb will take time and try the patience, but so will fitting a new carb and dialing it in.
Your old carb is a good one and I'll assume worked well at one time.
Me , I would rebuild and replace intake seals as they could actually be part of the problem you are having now (intake air leak)
bikestuff (07-21-2020)
No carburetor will work correctly on your bike if the intake o-rings and/or intake grommet has leaks. Period.
I will definitely rebuild my original carb also.
budha9109
07-22-2019 01:48 PM
