Do I need to rejet?
What if I wanted to go even smaller, like a 5” air filter? Here is the link to the lowbrow product I’m looking to use.
a lot depends upon media type
there are flow calculators on the net you can use. an engine needs a finite amount of air so the surface area of the media must allow atleast that air flow, note this is for max rpm so lower rpm would be less of an issue. however, less area = more maintenance, they do not come with a restriction indicator.
so overall will I need to run different jets in order to ride with a smaller air cleaner?
