CV 40 to CV44--Manifold the same??
why on earth go from a 40cv to another cv carb? Ditch the cv and go mikuni HSR 42,45 or 48 depending on your needs.
Curious,why the need to increase the bore size ? How many cubes are you running ? If you're running out of fuel, Wood Performance has a kit to improve the flow and capacity in the existing carb without re-configuring everything. If you have cruise, add that to the mix for a carb swap. Will you be tuning it by ear or has a shop dialed it in?
This is my 80" build with a Wood modified 40 CV with the High flow fuel kit. 86hp /92 tq, you can get good performance from a 40 CV without having to swap carbs. You can see the date of the runs (2007), it's been trouble free and the only time it had to be touched was when I dumped the Thunderheaders. The bike performs well and @ 5000' running in the Hills I'm averaging in the high 40's.
https://www.hdforums.com/forum/evo-c...o-numbers.html Post # 48
eighteight (06-12-2020)
"05 Fatboy---95" screamin eagle cast pistons, Andrews 37 cams, Cometic head gaskets, Big Boyz street heads, DTT ignition.
In talking to others, I think I will go with the Mikuni HSR 42. Understand it gives better throttle response BUT a little concerned about what I hear about bad mileage with Mikuni. Peeps say the CV44 might be a bit much fot my build.
