04 softail standard
05-13-2020, 09:34 PM
04 softail standard
I have a 04 softail standard it has the stock carb on the bike could i get a different carb put on it that woyld do better then stock 1 make it more peppyier its got se cone and short shots on it i want it to be a lil snappier
05-14-2020, 07:00 AM
Did you check the jets? Sounds off....
05-14-2020, 08:18 AM
Hi there JWE my friend. I moved your post to the proper location where it will also apt get more replies.
Kindly see below.
Also in the welcome area are our rules in the upper part of the welcome area. You may want to check them out.
Thanks JWE and again, pls see below.
05-14-2020, 10:17 PM
Mikuni is the best carb I have ever used on a Harley, especially if you want "peppier".
05-15-2020, 05:42 AM
Can`t imagine that your stock engine can use/consume more air than is being supplied by the stock carb
( Stock jetting is usually lean / see post #2 )
Mr.Softy
09-16-2017 02:41 PM
HDKyle
10-15-2016 11:09 PM
yank
06-06-2011 09:49 PM
Johneb48
07-12-2007 03:30 PM
Johneb48
07-12-2007 09:34 AM
