Keihin carb
Keihin carb
I am looking for an OEM Keihin 40mm carb. I have tried googling but only seem to find no-name brands making replicas. I am hoping someone's google fu is stronger than mine. I am currently running a Mikuni HSR42 but it seems the float is stuck. My mechanic tried to clean the carb with no luck so he suggested replacing it. I am hoping if I swap it back to the Keihin I can get back a little bit of my MPG. Riding 140mi round trip every day adds up when I am stopping at a gas station twice a day.
unless there is damage to the carb body itself, the float assy can be changed or fixed.
sounds like the mechanic lacks experience, wants to sell parts or does not want to deal with the issue.
70 miles to a 3.5 gallon tank does sound excessive but then again
my 01 sport will do near 60 mpg being babied and very low 30's mpg being cranked up.
i am not stock by any means but ride style makes a diff.
you might try Marks Carbs in Arizona, he specialises in OEM Keihin Carbs, he can supply you with a refurbished Carb or rebuild yours . . .he also has an ebay store "marks_carbs" where he lists carbs that are for sale & already done . If you want i can look up his address , i got it heir some where .ok heirs Marks address if you want to send him a Carb to rebuild : Mark Perry 3745 E. Fillmore St. Phoenix AZ. 85088 Mark says he has over 40 years experience , so i am pretty sure he can help you out.
I know this is an ancient thread... But 27 mpgs.. That sucks!
I was getting 49.7 with 200 main jet, dropped to a 195 and went to maybe 41 mpg...
But 27 mpg..... That thing would be replaced..
Hope you fixed your issues tho OP
eighteight (01-08-2021)
