Super E running with idle mixture screw seated
Look maybe we're not communicating well or something but we established a few posts back the carb isn't right. Seated down yes you will see the needle a bit, adjusted correctly you should not. You say it won't run if isn't seated.
Drop any thoughts of screwing with anything for a minute and answer a few questions so we can help you.
Did the bike run before ?
What's the bikes history leading up to you finding the carb set wrong ?
Did you just buy it or something ? carb swap ?
Did you change anything else ?
Have you checked the jets yet to see what the are and if so what ? list them for us.
Did you do an intake leak check to see why the carbs so far off ?
Do the basic trouble shooting before you start tearing into things please.
