Cv carb tuning last 5 percent
None detected.
fingered the slide up and down
60 degrees here
Added 190 main as my 195 is still in the mail
test ride, no cough
added 4 discs to pipe no cough
added passenger no cough
running well
will probably fatten slightly later and advance the ign curve via the twin tec
Thank you all for your help
edit this is completely subjective but the combination of 2.88:1 gearing (changed previously) and this years engine upgrade make this bike a joy at 85mph
FWIW, engine is “happy” !
That sounds like you got it worked out! You need to buy some fresh plugs and do a chop test in order to get a good reading. There's several web posts on how to read plugs. Even timing marks on the strap. But, I'm curious as to why you want more if it's running fine now. I'm a bit OCD myself and alway think I can get more. I'm not a fan of some dyno tests. To me, it seems the tech is just trying to break your bike. If your end game is a racer keep going. But if it's something you can be satisfied with with a passenger then I'd be tempted to be happy. Congrats though!
[QUOTE=eighteight;19008077]Checked for leaks with propane.
None detected.
60 degrees here
test ride, no cough
running well
QUOTE]
the fwiw update: the above combination worked well but mpg was poor
replaced the 50 with 48
running perfectly
44 mpg @ 65-75 mph
None detected.
60 degrees here
test ride, no cough
running well
QUOTE]
running perfectly
44 mpg @ 65-75 mph
Received 5,562 Likes
same as recorded when it was 88 “
no complaints here
eighteight (08-02-2020)
