Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Mikuni jetting for V-111?
Old 02-20-2020, 12:08 AM
Scott Barnhart's Avatar
Scott Barnhart
Scott Barnhart is offline
Stage II
Default Mikuni jetting for V-111?
Hello all! New to the forum so I'll start with an intro, my name is Scott and I'm a mechanic in Philadelphia. I work at a motorcycle shop and with some trading came into a S&S V111 with a HSR42. Now I'm in the process of tuning and I'm a bit leaner than I would like to be, especially with a high performance motor. I was curious if anyone here has already tuned a set up close to this? It would save me some time, money, and aggravation. Any info is greatly appreciated. Thanks!
Old 02-25-2020, 02:20 PM
Madnss's Avatar
Madnss
Madnss is offline
Received 1,109 Likes on 592 Posts
it doesn’t take much time and money to follow the mikuni hsr tuning manual and dial in the crab. I’d guess 180 main and go from there. The manual literally walks you step by step for each circuit to tune.
Old 02-25-2020, 06:19 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
If you put a 180 main jet in that it will be drowning in fuel. 22.5 or 25 slow jet, but I'd try the 22.5 first, then 165-172.5 main jet.
m
Old 02-25-2020, 10:53 PM
Scott Barnhart
Stage II
Thanks guys. I understand I should just go and tune it by the tuning manual, I was just trying to get a baseline. Brand spanking new motor, didn't want to get anything too hotby running too lean or anything. I'm at a 25 slow jet, 160 main, needle is on the second notch from the bottom, accelerator pump nozzle is a 70. I'm a hair rich, which I don't mind, just having a hiccup on start up now. Doesn't want to fire without some throttle. I'll figure it out though. Thanks again for your input guys!
Old 02-28-2020, 06:44 AM
Madnss's Avatar
Madnss
Madnss is offline
m
I figured that many cubes would take more. Guess not, my 48 hsr runs 195-215 depending on DA haha
guess I’m used to that and over guess main jetting on bigger cubes
Old 02-28-2020, 03:03 PM
marcodarq's Avatar
marcodarq
how many more cubes??? it would have to be a monster engine and or a very poor exhaust system on that set up. i'vve tuned lots of 100hp plus and 100 inch plus engines on my dyno and RARELY had to go larger than 177 main jet.
what do you have?
m
Old 03-04-2020, 06:21 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Bump the pilot to a 27.5 and the main to a 165....see how it reacts.
Shy of a dyno tune, trial and error until you find a combo that you want/like.
Scott
Old 03-08-2020, 09:44 AM
Madnss's Avatar
Madnss
Madnss is offline
what do you have?
m
I was ball parking the 111ci and was way off according to you and hillside. I’m used to My 76-77 CI Xl’s. Both 48 miks 185-195 on the street one and up to 215 on race one. U4.4 fuel in the race on.
77 CI, when I ran a Kevin benson racing super D main was 92-96. Also ran a SA RACING super D with custom jets from Steve. Yuuge jets running c45
Old 03-08-2020, 07:23 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 5,460 Likes on 3,639 Posts
There used to be a time where nobody in their right mind would put an S&S E carburetor on anything smaller than 100". But truth be to the fact that it's not about cubic inches it's about air flow and what your heads can do and how much your pump can displace. Now on these v111s that S&S is putting out they're sending them out with E-Series carbs, yes.. BUT...
​​​​​ Don't you think they're doing that just to meet EPA standards? I mean let's be realistic here, unless the heads on those motors suck and they're not moving enough CFM then yeah an E-Series carb will suffice.. I don't deal much with mikuni's or CV carbs and I know a lot of people swear by them, yes they're not bad but a HSR 42 on 111 cubic inch motor? Not sure it's going to be a good match.. I could be wrong but that's just my opinion..
Old 04-26-2020, 08:52 PM
Yetti's Avatar
Yetti
Yetti is offline
6th Gear
Default 96 FXSTC v111 mikuni 45mm
buying a v111 tomorrow and a mikuni 45mm. The guy helping me is a retired harley mechanic and die hard s&s guy. I'll let you know what what do when I get her going.
Quick Reply: Mikuni jetting for V-111?
