Accelerator Pump Help
https://cv-performance.com/harley-cv...-parts-diagram
There should be a metal disc on each side of the diaphragm. That metal disc has a center disk. The flat center disc is for the accelerator pump rod or faces up. The inner disc that is not flat faces down towards the spring. The diagram above shows the small O-ring. YD
