CV Carb Needle Jet Holder Different
Was attempting to change my main jet today on my 1998 Fatboy.....The tube/holder is different, there is no
hex head, and the main jet threads are smaller so the jet that I bought will not fit. Anyone recognize the one in my hand?
According to the parts catalog it should be part number 27101-88. (Shown below)
Not sure what to do, what do I have? Can I just replace it with that part number from Harley? Thanks in advance.
[CITA = pastorerik; 18491955] Estaba intentando cambiar mi jet principal hoy en mi Fatboy 1998 ..... El tubo / soporte es diferente, no hay
cabeza hexagonal, y las roscas del jet principal son más pequeñas, por lo que el jet que compré No va a caber ¿Alguien reconoce el que tengo en la mano?
Según el catálogo de piezas, debe ser el número de pieza 27101-88. (Se muestra a continuación) ¿
No estoy seguro de qué hacer, qué tengo? ¿Puedo reemplazarlo con ese número de parte de Harley? Gracias por adelantado.
[/ CITAR]
Si lo tienes y me lo puedes vender dime, saludos
[/ CITAR]
I'm a bit confused about the needle jet being silver, and a vital component . . I have a 1991 FXSTS with OEM cv carb. my emulsion tube and main jet ( needle jet) look the same as the photo. Wait a minute .you mean the little steel one size fits all, tube thing that goes through the body of the carb , and the jet needle goes into it. I was scratching my head for a minute .
"you mean the little steel one size fits all, tube thing that goes through the body of the carb , and the jet needle goes into it"
Yes, that is called the needle jet, and is the part you described. The positioning is critical and can sometimes be placed either upside down or lost completely.
what you have pictured in the original post is the emulsion tube and main jet, not stock, most likely dyno-jet hence the difference in appearance. the round emulsion tube and jet is hallmark of DJ, the stock HD emulsion tube has the 5/16 hex to screw in the carb body, with a round head, flat blade screwdriver slot to screw in the tube. there is also a difference in the main jet numbers between DJ and HD.. main jet size with Kehin/HD jet will vary based on your exhaust/engine mods, and the number will be different than a DJ main jet.
m
m
