Popping and misfiring. Help needed.
So this all started on the highway at about 70 miles an hour. I didn't think much of it at the time but every once in a while the bike would pop or lurch and lose power. It rode fine around town but yesterday I was back on the highway and it started again. slowly at first but after a while I couldn't get any power above 2000 rpm. Today I pulled the air cleaner off and noticed that there were cracks in the tubes that come from the cylinders and slip in behind the air filter so I replaced those but it was no effect. I assume it's a leak somewhere because if I hold the choke it seems to run fine. Now at in town speeds it's missing and popping loudly. The bike is a carbureted 2002 fatboy. Anyone have and thoughts on what else it could be and/or how to check? Thanks.
Video evidence
Oh I am. I checked with brakleen and nothing, didn't even die a little. Tried again with some wd40 and even a little carb cleaner, no revving up. I did notice an odd fluttering noise though so I pulled the air cleaner off and took a short video. You all probably know if this is normal or not a lot better than I would. https://www.dropbox.com/s/08gnemrvvub357z/20160718_190825.mp4?dl=0
