Popping and misfiring. Help needed.
Okay, so I think I found my issue. I said at the start that those tubes were cracked and what not so I replaced them(with some fuel line from autozone) but I guess I cut them a bit too long so they were forced up against the metal plate on the filter blocking them. I cut them a bit shorter before I put the cover back on this time and now she runs like a dream. Seems to have more power than before with no backfiring or power loss. I only got up to about 55 tonight so I guess it's a waiting to see how she does on the highway now.
that is wierd
i though engines do not need air filters to run?
i have not had a motor stall because it has no filter or cracked breather tubes.
i just rebuilt a 05 rk 99b cv carb and did not replace any Breather Tubes.
one breather tubes does have cracks. will be replaced one day.
cracks did not make a differance in performance.
looks like your carb needs cleaned.
guess if the motor is not stalling after the shorter tube fix.
why mess with the carb anymore.
stoney
stoney
stoney
stoney
Moondogger
07-08-2012 10:11 AM
Spud17
05-25-2012 06:09 PM
