Which epoxy should I use to glue a hose barb fitting back in to a Petcock ?
No, use Loctite blue thread locker. If you own a Harley you should own a tube of it for nuts and bolts..
That brass fitting is just a firm press fit. I think a slight taper in the bore and is what holds it. The Loctite blue is a little extra insurance.
Protect the metal, but a pair of channel locks, or a small c-clamp will press it in if you don't want to remove petcock. If it is of, then a vice I works, just don't force it too hard. that aluminum housing can crack. YD
greenbax
11-06-2014 08:43 AM
