06 CV carb fuel issue
06 FLHT CV 40 carb. At half tank the bike stops getting fuel. I get about 80 miles then I have to put in 2.5 gallons. I pulled the petcock, screen is clear. Checked the vacuum line, no issue that I can see. Also checked the tank vent (under cap), not plugged. Bike runs fine until that half tank.
I ain't assuming that you ain't aware of reserve capacity...but does your your petcock have a a reserve setting?
I have measured the tank capacity on my 2001 FXD and honestly right off hand I don't remember the exact usable capacity to quote, but I do remember that it holds just over 3 quarts of gas in reserve and it seems to me it is like 3+ gallons available in the main setting for MY tank...and I also know from experience that when that gas gauge gets down to that red mark, it's gonna spit and sputter and bitch until I reach down and twist the petcock up to reserve...and head for the nearest gas station...
You haven`t told us if you have fuel flow when the valve is switched to reserve...
Strange thing is that the next tank I ran 100+ miles and burned 3.8 gallons as normal without issue. Maybe when I removed the petcock something flushed off the screen? I have a Pingel on the way.
Used to see it a lot with tanks that got painted it if something got into the tank.
I installed the new petcock today, made an observation that I thought I would share: my OEM petcock was flowing fuel even without vacuum. I had the vacuum line disconnected and it flowed on both on and res. I installed a Pingel that doesn't take vacuum so I guess I have eliminated that issue. Oh, and the crossover line is flowing fine.
