What to do to the carb after I install shortshots and new a/c?
What do I do to the carb after I install shortshots and new a/c?
I just bought a 04' xl1200 custom and I am planning on putting V&H shortshots and a new free flowing a/c.
My questions are:
1) Should I re-jet the carb myself or to the dealer? I have worked on cars for years but this is my first motorcycle.
2) Also what aftermarket a/c do you recommend?
Thank you for your time.
Roland
My questions are:
Roland
rejet or not to rejet !!!
My questions are:
Roland
My questions are:
Roland
unless you like the popping !!! but it will be very lean !!! go up one size on the main jet ...if it is still surging at cruz steady speed ..go up one more time or add a washer under the needle ...
42 or 45 pilot, 170 or so on the main.
Remove the welch plug that masks the air/idle adj. screw, and set that between 2 1/2-3 turns.
Throttle wheel idle should be set at a comfortable idle, or around 1000 rpms.
Should get you in the ballpark, shy of a dyno tune.
Scott.
Scott.
