cv carb question. need advice
I have been searching the forums and "how to's" for adjusting the air flow Screw and cant find my problem anywhere..........maybe You can help.
here is the issue. stock jetting in carb,...but it only runs Smooth when the rich mixture screw is CLOSED. I can maybe open it a 1/2 turn before the motor slows down. Whats going on ???
Air leak, to rich , to lean or carb issue inside ??
I have removed and meticulously cleaned the carb. It has been apart before.
Received 24,407 Likes
