2008 Road Glide- No Tail light- fuse keeps blowing
Does anyone have a wiring diagram for 2008 Road Glide? I keep popping fuses and have no tail light- brake light works, headlights and turn signals work.... other than a rubbed thru wire I was hoping for some guidance on other preliminary checks. Would an oil pressure gauge illumination wire to ground cause a short (This gauge light is also not working (the other 3 are) haven't pulled the fairing yet.
TIA
TIA
Just guessing but there is usually a plug under seat for the harness that disappears under fender heading back to taillight. Unplug it and ohm it to frame ground or just see if it kills the fuse popping.
Only as a suggestion, be sure to make your next new post over in the new member welcome area.
Just in case..
Welcome to the HDForums and hope
you enjoy your ride with us ______
Just in case..
TIP TOP TIMMAY (03-29-2023)
TIA
TIA
hhkiwi
04-15-2015 03:41 PM
