procharged SE120R
or is this the way to go ?
throttle BoDy – electronic throttle
screamin’ eagle
® Pro high-floW 64mm efi
to provide the ultimate results, race engines need all the
unrestricted air they can get. Designed to maximize the
performance of your race Xtreme component-equipped
Se120r engine, this throttle body is ready to take on the
track. the gigantic 64mm throttle Body is precisionmachined
to ensure a smooth air flow when combined with
the Oval-Ported High-Flow Intake Manifold and port-matched
Hurricane Cylinder Heads. Screamin’ eagle
® High-Flow Fuel
Injectors P/n 27796-08
(sold separately) are recommended.
All eFI models require eCM calibration
(priced separately).
for race application only.
27300033
27300033
$499.95
17799-10 and High-Flow Intake Manifold P/n 27300035
Fits ’08-later touring models equipped with Screamin’
eagle Pro Hurricane CnC Oval Ported Cylinder Heads P/n
There 69 lbs/hour injectors at 58 psi fuel psi. They are not HD injectors there 38mm oring to oring. We custom build them also the ones he has our deki shortys.
69 lbs per hour = 8.69 grams/per socond
The biggest HD/SE has is 6.3 g/s
6.3 g/s = 50 lbs per hour
5.3 g/s = 42 lbs per hour
4.9 g/s = 38 lbs per hour
Also How we pick the right injectors is buy what size engine and how much power it will make at what afr table for duty time on injectors.
I hope this helps..
I hope this helps..
