Blowers/Turbos/Nitrous Oxide For you Gear Heads. Here is the place to discuss your souped-up, sophisticated, out of control and money pit monsters.
I finally pulled the trigger and decided between blower and turbo..
Old 04-15-2011, 05:29 PM
Troy L's Avatar
Troy L
Troy L is offline
Default I finally pulled the trigger and decided between blower and turbo..
I ordered a trask turbo (intercooled) and Thundermax Auto Tune to put on my 2010 Electra Glide Classic..
the bikes already making 122/121 with a stage 4 103ci at 10.75 compression ratio..
should have everything in the next 10 days so ill keep this thread updated..
before everyone starts off with what are you thinking or it will never last , i already know that but lets try it anyway...
going to run it and tune it on 100 or 110 unleaded..
a new motor is in the near future...
Attached Thumbnails I finally pulled the trigger and decided between blower and turbo..-picture-or-video-004.jpg
Old 04-15-2011, 05:45 PM
BadBagger08's Avatar
BadBagger08
BadBagger08 is offline
Nice. I bet ya can't wait. Ought to run like a raped ape when finished.
I know I can't. I see every1 out on their bikes. just a couple more weeks I keep telling myself.
Wish I could afford a turbo/supercharger.
Old 04-15-2011, 07:52 PM
Turbo ray 44's Avatar
Turbo ray 44
Turbo ray 44 is offline
Default Good Luck
only have a couple of questions?
With 10.75 compression what's the plan so that you effectively seal the top end? especially when your running just a little boost? a little more boost and you will be havin fun and pushing the head gasket limits to the max.
Keep us tuned in, sounds interesting.....
Old 04-16-2011, 09:59 AM
Troy L's Avatar
Troy L
Troy L is offline
im running cometic head gaskets , im not sure how long they will hold but ive had really good luck with them in drag racing high boost applications ...
any suggestions ?
Old 04-16-2011, 11:08 AM
Turbo ray 44
Default good choice
Ran cometic gaskets with my 124" for 80,000 plus, 4,000 plus with the Turbo. The Turbo w/an 8# boost spring started pushing the head gaskets on the 75,000 mile lower end.
SOLUTION...were stepping the heads and cylinders and adding a 14# boost spring....
you might want to consider Turbo pistons w/8.1 compression ratio, then you can add lots of boost.
have fun.....
any suggestions ?
Old 04-16-2011, 12:56 PM
FastBagger07's Avatar
FastBagger07
FastBagger07 is offline
Who did you buy the Trask Turbo from.I see Frank at DragosBikeworks is a dealer for them now.I agree with turbo ray.You may want to change out your pistons to a lower CR.It's all about the boost when your dealing with forced induction.
Old 04-17-2011, 10:57 AM
Troy L's Avatar
Troy L
Troy L is offline
i got the turbo kit from Trask directly, Nick gave me a pretty good deal since i bought the kit and thundermaxx , injectors all at the same time..
I know that lower compressions would be a smart thing to do but i like to do things the hard way...
Old 04-17-2011, 07:16 PM
FLSTF's Avatar
FLSTF
FLSTF is offline
Default Compression
How much compression can you run with a turbo? If you already have a build with good heads can you just change pistons and keep the rest of your build the same?
Old 04-17-2011, 09:50 PM
Turbo ray 44
Default desired compression
The closer to 8.1 you are the better..then add boost and hang on.
CP makes a thicker topped dome so that boost can be added w/less chance of damaging the top..
good luck..
Old 04-19-2011, 09:27 PM
BadBagger08
Why didn't you just go with a O Ringed head and a grooved cylinder and run a copper head gasket? This is how Alcohol and top fuel cars are done and that's a hole lot boost and cylinder pressure. I blew a head gasket on my blown small block and went this rout and never had a issue again. Jim Oddy did the head and block work for me.
Can you show some picks of your heads and cylinders when you get them back? I'm very interested to see the work.
Quick Reply: I finally pulled the trigger and decided between blower and turbo..
