Boom audio system full review
After reading through literally thousands of post on this site concerning the audio upgrade options I finally pulled the trigger today. I have had a real hard time finding a unbiased review on the boom audio amp and 4 speaker system for the 14 Ultra Limited. I understand the aftermarket world typically provides a better product at a cheaper price.
There are a few reasons I went down this road.
1. I got a smoking deal on the system $700.00 (1K on HD website)
2. I want a plug and play system. This Boom system is designed to work with no mods (other than the flash) and should be a painless install.
3. I have heard great things about JM audio, and this was originally my plan, but I have heard some horrible things about JMs customer service. It may be all BS, but it was enough to scare me away.
I am sure for 700 bucks it will be a substantial upgrade to the stock system.
I plan on getting a decibel meter and doing a full review to let other folks know if its worth doing.
http://www.harley-davidson.com/store...08-76000411--1
I don't think that J&M has bad product, it's just how they push their stuff here. I'm okay with that, but decided to go with the Biketronics line. Personally, you will be WAY better off with either of them then HD's boom. If it's the money, do some research on this forum for some of the other options. Do yourself a favor, stay away from the boom stuff, I bought a bunch off their speakers, they are only slightly better then stuck, which isn't say much.
no doubt better quality too
yep that's a pretty good deal.
yes sir it should be. install, flash, ride.
on the contrary, their customer service is impeccable IMO.
not sure I would use the word substantial but it will certainly be better than stock if it's flashed correctly.
not the power of the amp you need to be concerned with but the current draw of said amp. Good luck in finding actual specs on current draw of any boom amp. But all things considered, I don't see how an amp that has a main power wire of 16ga is going to draw very much current at all. IMO, the recommendation is BS.
After reading thousands of posts, you still chose the Ka-Boom ?? WOW !!
My main reason for NOT going with what the dealer recommended, would be because they flat out lied about the charging system.....
J&M may has one of the BEST customer service departments in the business...If you have a problem with the Ka-Boom set-up, will the owner of Harley Davidson personally handle your problem ??? NO WAY, but the owner of J&M will....
Will the Ka-Boom be better,.....sure, but so would anything...will it be $700 better ?? Not in my opinion....
If I were you, I think I'd start over with my 'research'......
That said. . . GP is being polite. Since January I've replaced at least 4 boom systems on bikes. Guys arrived at the same conclusions. . . "They got a good deal" so they jumped on it. Bottom line: Once they got it. . . They hated it and wanted something better. You can do a hell of a lot better than the boom system for 700.00 bucks and by the way JM was my first upgrade years ago and I found their customer service to be excellent as well.
