Hk reception
Hk reception
Hey. i need some advice on my hk set up. 09 classic. A few years ago i took out the stock antenna cable and tried an under the fairing one with mixed results so i decided to put the stock cable back in. meanwhile, my radio went south and had it replaced with a rebuilt one. i have the same set up in the rear as a street glide with the short antenna but can.t get the same reception as my buddys 08 glide. his works better without the antenna than mine with one. if i grab the antenna the local station comes in much better. is there and adjustment on them to tune in local stations. any advice would be appreciated. thanks.
Although I didn't have any reception issues to start with, I switched to this hidden antenna, which gets consistent high reviews in these forums, and get even better reception than I did with the stock short antenna:
http://www.ebay.com/itm/Hidden-ANTEN...-/380910587466
BKSinAZ
06-11-2014 01:04 PM
