2014 Flash Question
2014 Flash Question
I currently have the J&M Rokker XX 6.65 speakers in the front faring of my 14 SGS and a RF PBR 300x2 and radio flashed for 2 speakers, 1 amp. It sounds great!!!
I am about to add a tour pak with speakers. I would like to run the tour pak speakers off of the head unit for now. Is their a flash that will work like my current flash but will activate the rear speakers off the head unit? I would rather not have to use a Magic box if possible.
Also, will 4ohm speakers do ok with head unit, or should I go 2ohm?
Thanks!
Thanks!
JM's are two Ohm speakers. If you like the JM set up Just buy another X2 and another set of JM speakers. . . Or you could sell the X2 to help you buy a four channel amp from JM.
