ASWC-1 / Metra install AND PROGRAMMING (left push as MUTE) Guide
#31
#33
#35
Sorry for the late reply - your Q got buried...
Metra goes in from the back...oopppssss gotta be careful nowadays - inappropriate s.xual content LOL
I mean bracket is goes into fairing from within the fairing. so you are good to go... it looks a LOT like stock HU outside. i can recall it has the same type of weatherstrip. I kept the bracket I had... Cannot call the vendor out as it might get me into trouble (LOL2), but it is the one that does Bike (elec)tronics.
sold it together with the BT100x to a fellow (ex?)forum member so cannot physically look at it.
hope this helps
hope this helps
#36
#37
Okay, need some confirmation on connections. Metra 99-9600 kit, ASWC-1, being connected to a Kenwood HU.
If my understanding of what I've read is correct the following is how the connections are made.
1. ASWC-1 wiring harness not used.
2. Metra wiring harness gets red, black, and yellow connected to red, black, and yellow on the radio harness.
3. Female 3.5 jack from ASWC-1 kit gets connected to brown wire to blue/yellow from radio harness (brown/white not used).
4. Pink/white from handlebars left side (sitting on bike) gets cut and handlebar side gets grounded to either cig lighter ground or frame. Other end of pink/white gets isolated.
5. Connect the two 3.5 jacks, the Metra 23 pin plug to the factory wiring harness and the 12 pin end to the ASWC-1 black box.
6. proceed with programming.
Is this correct or have I mixed something up? Thanks!
#38
#39
#40
Awesome, thanks! You are correct on the 3.5 plug. The only one built in to the unit is for the external BT microphone. So the ASWC-1 provided one gets connected via the brown wire to the blue/yellow on the HU harness. The brown/white doesn't get used. The install and auto-detect went smooth. Thanks again!
