look at this AMP! Lanzar Class D 3200W amp RDA754D
just ran into this one, it MIGHT fit in the fairing...
while I was on the website I lookad at 4 channel class D amps... too bad it is on back order....
Lanzar 3200W Reign Series 4-Channel Class D Full-Range Compact Hybrid Car Power Amplifier (RDA75.4D)
General Features:
Reign Series 4-Channel Class D Car Amplifier
RMS Power Rating:
RMS Power Rating:
4 ohms: 250 watts x 4 chan.
2 ohms: 400 watts x 4 chan.
Bridged, 4 ohms: 800 watts x 2 chan.
Max power output: 3200 watts
Pulse Width Modulated MOSFET power supply
Wired remote bass level control included
Double sided SMT circuit board
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +18 dB bass boost at 50 Hz)
Soft start turn-on
4/3/2 or Mono channel operation
Speaker-level (high-level) inputs with signal sensing for automatic turn-on
Preamp RCA outputs to daisy chain multiple amps
3-way protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heat-sink
Input sensitivity:
Level: 125mV-5V
Variable high-pass filter (50-250 Hz)
Variable low-pass filter (30-200 Hz)
Subsonic filter (24 dB at 15 Hz)
4 gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits from our website when purchased together with this amplifier.
Dimensions: 6-1/8"W x 9-13/16"D x 2-11/16"H
link
General Features:
RMS Power Rating:
RMS Power Rating:
Soft start turn-on
Input sensitivity:
Level: 125mV-5V
link
Found amp on Amaz... for 1 benjamin with Prime. so will order one BEFORE I order the RZ (other thread), so I can bench test it (and check if it fits the fairing - width is fine, it is the dept and height as well that are "worrying me").
I can always return ...
2 x 25 fuse is making me wonder about the output yes...
BTW - never dated a chearleader (but then again, we did not have them in Amsterdam back in the day)
