For anyone running these speakers, did you set the tweeters at +3 or leave them flat at 0? How easy is it to make the adjustment, and how much difference in the sound?
I thought that button was used to focus the tweeter? Thats what the button on mines does....
I'm not sure what you mean by "focus"? The 62.11 tweeter is adjustable in a 360 degree circle to aim the tweeter, and the level is adjustable by way of the chrome button to switch from flat to +3db.
Do you find you need to boost treble, or does it sound pretty good flat? Do you use the factory Infinity grills?
I'm running the 62.11s in my fairing, behind Hawg-Wired mesh grills. I also have a Hogtunes tweeter bar that I installed Infinity silk dome tweeters in, so I did not need to use the +3 setting on the 62.11s. I'm running a Sony HU, and use the "explode" eq setting, which gives a small treble increase but a greater boost down low. Sounds good to me, you need to try the speakers both ways and see which setting you like best. Unfortunately it's a PITA to switch the setting when mounted in the fairing, you need to dismount the speakers to get at the level button.
I'm running a set of Infiniti Kappa 62.11's behind mesh grills on my 14 SGS. You have to be careful, but I was able to change the setting by straightening out a large paperclip and poking it through the mess. Again, I say BE CAREFUL.
Totally agree with Poolboy they sound much better flat IMO. Of course I also have the Sony HU and tune them in the Xplode mode. Sounds dam good!
