Upgrade advice
Biketronics is a great place to start!! First thing you have to do is stay away from that freakin local audio shop. . .Those boys are gonna kill you. lol What kind of budget are you working with and do you plan on expanding your system in the near future or Just sticking with the two speaker set up?
I just want the 2 speakers. Not looking to expand into saddlebags or lowers or anything. I would like to have a Bluetooth HU and be able to hear it clearly at highway speeds. I will buy a piece at a time if I have to to get what I need to make it happen. What do you guys think of the new Jensen replacement HU? Worth the price considering it's plug and play and marine grade?
They said it would be $250 to repair and update. That's the price of a very nice aftermarket HU or a decent HU and install kit. I'm just weighing my options here. Does the mod you were talking about change the output to 4 ohm?
Edit - This was their response to my email $150 as core. $250 repair…includes repair, all updates and mods to latest production specs, one year warranty, lifetime re-repair discount if needed (less than 1% do)
No Sir. . I was refering to increasing the Stock HU to 4V pre-outs. The general Idea is that a higher voltage input to your amp will require less amplification and therefore less noise. You might check with Iron Cross for verification but I think the stock HU is only 2V before modification. Nutz my mentor and ultimate audio guru on here always recommends 4V pre-outs.
Originally Posted by Da Shadow View Post
I found it.
Iron Cross Audio
Sponsor
Garage is empty, add now
ICA's pre-amp mod can be done to a higher volt output if the amp needs one. However, keeping the DC potential as low as possible and allowing the amp to work with a cleaner signal (Higher DC means more noise potential) is the better way to go. Most of the better amps gain controls will allow for the use of the cleaner, lower level output.
Wow...that post was from Dec 2010.
Yes, we said that a higher v output was available (3 years ago we were at about 2) As we pushed it higher, we we're getting noise in the signal, so we settled at 3v...that was the optimal voltage we could achieve with no noise riding on the signal.
We never made a claim that we would install a pre-amp higher than 3v.
Did I miss something??
__________________
http://IRONCROSSAUDIO.COM
The above I copied from a thread in which Iron Cross responded to a conversation regarding output levels.
I believe Iron Cross does 3V outputs but they are convinced that 3V is a good level and with their reputation I would have no reason to doubt their word.
I found it.
Iron Cross Audio
Sponsor
__________________
Something to add:
I believe IC's statements regarding 3V are for the stock HU. If you search their posts regarding the stock HU they talk about the pre-amps in that unit being designed by the same folks that design and build some very nice equipment so the pre-amps in that unit are not junk, however, the output amps leave a lot to be desired and that is why it is best to bypass them. I like my stock HU and will have this mod done to enhance the performance of my four BT 7.1s and BT amp. Wanted to do it last year but the weather got good and I figured I would wait for cold weather this year to send it off. Currently my system is great and can be too loud. It is clear no matter how fast I ride but I won't feel it complete until I get rid of the line level adapters, or whatever they are called.
I found it.
Iron Cross Audio
Sponsor
__________________
I found it.
Iron Cross Audio
Sponsor
__________________
The new Jensen makes modding the stock HU problematic... pre-amp outputs, blue tooth conversion, and Ipod controls add up to quite a bit of money. I've found the Jensen unit available for about $409, seems to be a deal if the stock unit can be sold to offset the cost.
Thanks for the advice fellas. I'm still not sure I want to keep the stock HU. That seems to be the cheapest route but not necessarily the best. I definitely want it louder than stock and would like to be able to run a conventional 4 ohm speaker. Is that possible with the stock HU after Iron Cross does their standard mods?
