2014 Limted - Audio system
Hello,
Can you please provide some advice on audio selection ? I have a 2014 Limited.
1-I like the infinity speakers kappa 62.11i
a- are theses speakers water proof ?
b- will these speakers fit in the front and rear
c- what adapters would I need if any
2- I like the RF T400x4ad or PBR300x2 running 4 speakers in parallel
a- wich one will be better ?
3- To install this system, is there anyone that can provide audio installtion kits , plate mounting etc
4- Magic box - I did not see 4 channel magic box, would I need to have 2 for using it with 4 speakers ?
Thank you so much for your assistance
Hello,
1-I like the infinity speakers kappa 62.11i good speaker!
a- are theses speakers water proof ? water-resistant yes, waterproof no. You'll be hard-pressed to find a waterproof speaker.
b- will these speakers fit in the front and rear Yes
c- what adapters would I need if any I don't believe any adapters are required
a- wich one will be better ? 2 totally different amps. If you can get the 4 channel in there, it would serve you better on an Ultra/4 speaker system
3- To install this system, is there anyone that can provide audio installtion kits , plate mounting etc v-twinaudio.com
4- Magic box - I did not see 4 channel magic box, would I need to have 2 for using it with 4 speakers ? you will need both devices at bottom of page if you're using a 4 channel amp otherwise you only the 1 if using a 2 channel amp
