2014 street glide audio help
Help have been reading and re reading this section and came up with following list.
1.Seams a lot are going the pbr300x2 with kappa 62.11i speakers if I add magic box and amp mounting plate this is around $396.64.Small problem is no wire harness and no how to can be found .Is option one as good as it gets for NOW?
2.for ease of install was thinking j&m jamp-250hc14p amp with j&m 6.65 speakers all wiring and mounting plate included for around 899.48.Question is can this setup really be double as good as option one or at least a hole lot better ?? Could I or should I buy j&m amp for install ease and run kappa or bt speakers and save some money ???
3.Please if there are better options please tell me. On a side note no real plans on adding rears or lowers so must have best fairing setup possible.
j&m is plug and play and you are paying for that.
At the top of this forum there is a sticky with how to's on installing many different variations. They are all pretty much the same exact process. If you can even just crimp wires together you can do it. If you can solder and heatshrink even better. Just give your self a long afternoon and you can knock it out easy.
The J&M Performance series amplifier kit (#JMAA-180HC14) (found on this webpage http://www.jmcorp.com/SeeProducts.asp?PF=50 )) for the 2014s is reasonably priced & will give you 90% of the sound and performance of the J&M ROKKER series ,,,,,, but at significantly lower cost ,,
this amp kit will work with most any speaker from 2-8 ohms impedance and rated to handle up to 90w RMS power ,,,,,,
and when you use the HD.Forums discount promo code, it is even a better value ,,,,
all plug-n-play into the 2014s, with lazer-cut SS mounting tray and Tucson AZ made custom wiring harnesses, for an easy, no hassle install ,,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
