speaker plugs ?...
see post #16
or even easier would be to call hogtunes or Biketronics and just buy the prewired connectors..
https://www.hdforums.com/forum/audio...tune-lids.html
I can only speak for Hogtunes and Biletronics.
Hogtunes came with a harness with quick disconnects by the bags. If you rearrange the pins, it will plug directly into a pbr300x2.
Biketronics made me a custom harness. I only have one set of wires under the tank, and then it splits off into two connectors per channel, one for my bags, one for my tour pack. When both connected they run in parallel.
They also made me the shrink wrapped leads l have running through my engine guard. They can make it any way you want.
Or you can make your own out of regular wire, shrink wrap, and Deutsch connectors.
