amp stability
how are you planning to hook up?
titans and polks together on Front out of amp and Pioneers on the back?
SS is 2 ohm stable...
as you know titans are 4 ohm
polks 2.7
pioneers 4
polks together with titans or pioneers will drop the impedance below 2 ohm(1.61194029851 !!!)
not sure if I would do that / if it it save (not a huge drop on the impedance but it does go below minimum) ... leaving to the real experts (UN/GP/Pioneer74/...) to comment on this...
you probably saver to parallel the titans and pioneers (resulting in 2 ohm) and run polks alone. you can always fade the sound to either "set" through HU.
I run +4 to the pioneers.
go to:
http://www.speakerimpedance.co.uk
and look for parallel calculator - instantly gives you the impedance and Power to each speaker...
polks 2.7
pioneers 4
go to:
Bunker
Audio Systems
07-18-2021 10:09 PM
